Cheem
Aug 12, 2019Aspirant
Can a powerline adapter be used to connect an Orbi to my isp modem instead of a cat 6 rj45 cable
I want to locate my Orbi router in a room in the centre of my house so I can hardwire it with rj45 cables to my computer, Sonos and Hive heating hub located in that room (plus it’s the best place fo...
- Aug 13, 2019
Thanks to both of you for your help and recommendations. I now feel a lot better about my next course of action.
michaelkenward
Aug 13, 2019Guru - Experienced User
Now you know why I asked about the modem. It matters.
Unless you need fancy features, AP mode works fine with Orbi routers. It is common practice to use them in that mode, partly because the router bit is less capable than more "powerful" routers.
For example, parental controls and Armor won't work in AP mode.
If you want a more controllable system, then it might be easier to buy a basic modem only device than to faff around with complicated settings. For example, in the UK you can get the DM200 DSL modem for around £30. There are also inexpensive cable modems.
