noel1971
Jul 24, 2020Follower
CAN A RBS50 SATELLITE be hard wired to the RBR50 to give better coverage and speeds
Hi,
I have a RBR50 orbi router, and connected wirelessly are 2 x RBS50 satellites.
However, its a big house with thick block walls , Bison slabs between floors and loads of insulation. Therefore i cant get the signal to travel to other rooms.
I have ethernet connections in most rooms, can i connect the satellites thru the existing ethernet wiring to the RBR50 router rather than wirelessy?
Thanks
Noel
yes you can. And it works great. Its how I have most of my satellites connected.
