benmitchell1024
Jul 27, 2017Aspirant
Can an Orbi be connected to a Comcast gateway device?
I have a Comcast gateway device that is both a router/modem. Can I hook up an Orbi to the gateway?
SystemCrash
Jul 27, 2017Guide
Yes, I'm pretty sure the Orbi can be connected to almost anything.
benmitchell1024
How would I hook it up? Connect the Orbi to the Comcast gateway and just create a whole new wifi network?
- st_shawJul 28, 2017Master
benmitchell1024 wrote:How would I hook it up? Connect the Orbi to the Comcast gateway and just create a whole new wifi network?
Connect the Orbi RBR unit to the Comcast gateway. Log into Orbi via the web GUI and set Orbi to operate in Access Point mode. After Orbi reboots, log into the Comcast gateway, note the new IP address assigned to Orbi, Disable WiFi radios on the Comcast.
- makimmNov 11, 2017Aspirant
Just added my Orbi network but created a different network name than my existing xfinity network. Do I need to manually reattach all my devices to the new Orbi network? Or can I name the Orbi network with the same xfinity name?
I think I eventually need to put the xfinity router in bridge mode to get the better performance, right?
- OrbiPhilipNov 11, 2017LuminaryYes, bridge mode and turn off xfinity wifi. That's the setup I have.
- OrbiPhilipJul 28, 2017Luminary
I have the same setup as you. Turn off the wifi in the comcast Modem/router and use only the Orbi Wifi. And preferably, set the modem in bridge mode to avoid double NAT at the routers.
https://www.xfinity.com/support/internet/disable-xfinity-wifi-home-hotspot/
https://www.xfinity.com/support/internet/wireless-gateway-enable-disable-bridge-mode/- TgtermFeb 15, 2018Guide
Same setup here. Gateway set to Bridge Mode, xfiniti hotspot disabled. Saw the note about setting the Orbi in AP Mode, so I checked mine and discovered that I have my Orbi set to Router mode. Is this wrong, then?
If I reset the Orbi to AP mode, do I need to do other things? Sorry, I am not too familiar with this setting.
Thanks!
- guzzijasonFeb 15, 2018Apprentice
If you Xfinity gateway is in bridge mode, then your Orbi must be in router mode, as you must have at least 1 router on your network.
HOWEVER, with that said, if you but the Xfinity gateway in bridge mode, you lose a number of the newer advanced features that Xfinity is incorporating into their gateways, such as the relatively new XFi parental controls and network management features.
