benmitchell1024
Jul 27, 2017Aspirant
Can an Orbi be connected to a Comcast gateway device?
I have a Comcast gateway device that is both a router/modem. Can I hook up an Orbi to the gateway?
benmitchell1024
How would I hook it up? Connect the Orbi to the Comcast gateway and just create a whole new wifi network?
st_shaw
Jul 28, 2017Master
benmitchell1024 wrote:How would I hook it up? Connect the Orbi to the Comcast gateway and just create a whole new wifi network?
Connect the Orbi RBR unit to the Comcast gateway. Log into Orbi via the web GUI and set Orbi to operate in Access Point mode. After Orbi reboots, log into the Comcast gateway, note the new IP address assigned to Orbi, Disable WiFi radios on the Comcast.
- makimmNov 11, 2017Aspirant
Just added my Orbi network but created a different network name than my existing xfinity network. Do I need to manually reattach all my devices to the new Orbi network? Or can I name the Orbi network with the same xfinity name?
I think I eventually need to put the xfinity router in bridge mode to get the better performance, right?
- OrbiPhilipNov 11, 2017LuminaryYes, bridge mode and turn off xfinity wifi. That's the setup I have.
Did you use the same network name? Or did you have to reattach all your devices to the orbi network?
