benmitchell1024
Jul 28, 2017Aspirant
Can an Orbi be connected to a Comcast gateway device?
I have a Comcast gateway device that is both a router/modem. Can I hook up an Orbi to the gateway?
OrbiPhilip
Nov 11, 2017Luminary
Yes, bridge mode and turn off xfinity wifi. That's the setup I have.
makimm
Nov 11, 2017Aspirant
Did you use the same network name? Or did you have to reattach all your devices to the orbi network?
- OrbiPhilipNov 11, 2017LuminaryI used a different name and password. I wanted to move slowly and observe the performance difference.
I also split 2.4ghz and 5ghz onto different ssids
