benmitchell1024
Jul 28, 2017Aspirant
Can an Orbi be connected to a Comcast gateway device?
I have a Comcast gateway device that is both a router/modem. Can I hook up an Orbi to the gateway?
guzzijason
Feb 16, 2018Apprentice
If you Xfinity gateway is in bridge mode, then your Orbi must be in router mode, as you must have at least 1 router on your network.
HOWEVER, with that said, if you but the Xfinity gateway in bridge mode, you lose a number of the newer advanced features that Xfinity is incorporating into their gateways, such as the relatively new XFi parental controls and network management features.
Tgterm
Feb 16, 2018Guide
Okay, that makes sense. I must have misread a previous post that made me think I had it wrong. Not so concerned about parental controls...but what are the xfinity network management features?
thanks!
- guzzijasonFeb 17, 2018Apprentice
Tgtermwrote:Okay, that makes sense. I must have misread a previous post that made me think I had it wrong. Not so concerned about parental controls...but what are the xfinity network management features?
thanks!
It ws the XFi parental controls featured that I was really thinking of, but they keep adding other home automation and other feature that help integrate all the Xfinity products in the home together.
https://www.cnet.com/news/comcast-xfinity-adds-home-automation-to-x1-xfi-ces-2018/- emilieroseJul 30, 2018Aspirant
see above
