OldDogNewTrick
Aug 16, 2021Tutor
Can an ORBI be setup as an AP while mainting mesh functionality?
I would like to help a neighbor out with out of the oridnary (for me) WiFi setup. He has two homes on his property and would like to bring internet connectivity to second property. The primary reside...
Aug 16, 2021Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
OldDogNewTrick
Aug 17, 2021Tutor
Excellent info - the only part that I am unclear of is how do I pair the satellite Orbi after placing the first orbi into AP mode? I still want to leverage wireless mesh between the hardwired AP orbi and the secondary sattelite.
My undersatnding is that the mesh function is controlled via the app which no longer works once it's in AP mode?
- plemansAug 17, 2021Guru - Experienced User
It still functions as a mesh in AP mode.
You can connect to the router via app or the browser and then add satellites as you normally would.
AP mode simply disables some of the routing features not the smart roaming/mesh features
- OldDogNewTrickAug 17, 2021Tutor
Sweet! The note on the very bottom of this page confused me re: not being able to use the app.
- plemansAug 17, 2021Guru - Experienced UserGuess I rarely use the app and just login through the browser. Has a lot more features that way
