Pavioml
Sep 06, 2023Follower
Can an Orbi function of another router's Lan port?
I switched ISPs and have to use their router for the next 2 years. I don't want to transfer everything too a new network.
Can I just run a line from one of the ISP Router's LAN output ports to the Orbi's Internet (yellow) port?
1 Reply
Yes.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
