EdHpdx
Jan 08, 2022Tutor
Can an Orbi RBS 50 router be used with an ARIS CM820A modem?
- Jan 08, 2022
yes an RBR40 would connect. It'd use the slower 866mpbs backhaul but it'd still function and work fine.
EdHpdx
Jan 08, 2022Tutor
That is what I thought. Yes, they will not allow any other modem. I tried connecting and just got the magenta ring. Uggh, looks like I need to buy a new Orbi mesh router system that does not include the modem.
Jan 08, 2022Guru - Experienced User
You might be able to find the RBR40 or RBR50 for pretty cheap. a lot of people buy the kit for the satellites and sell the router.
Or even finding one renewed on amazon.
- EdHpdxJan 08, 2022TutorWould the RBR40 or 50 connect with the RBS50’s I have?
