Denoz777
Feb 01, 2020Follower
Can Cable Orbi CBR 40 connect with Orbi WiFi 6 Satellite?
Can we connect Orbi CBR 40 with Orbi Satellite WiFi 6?
CrimpOn
Feb 01, 2020Guru - Experienced User
"connect" is ambiguous. Yes, the yellow (WAN port on the RBR40 can be connected to an ethernet port on the WiFi6 satellite, and the RBR40 can be put into Access Point (AP) mode. It will be the same result as connecting any brand of WiFi access point using ethernet. It will not "become part of the WiFi 6 Orbi network", just as it cannot be made into a part of another WiFi 5 Orbi network.
