Zecapagodeiro
Aug 31, 2018Aspirant
Can I add 1 new router + 2 satellites to existing system with all 3 as add ons?
I already have a AC2200 system with one RBR40 router and two RBS40 satellites. If I were to buy additional system with same equipment can they be added onto my existing system where the new router wo...
Aug 31, 2018Guru - Experienced User
The RBRs work only as the main AP, they do not support extending wifi signals like the RBS do.
Zecapagodeiro
Thanks. But if I buy the 2 satellites that come with the new router I can at least add those to my existing system, correct? Seems to be the cheaper way to buying the additional satellites even if you don't use the new router
- FURRYe38Aug 31, 2018Guru - Experienced User
Yes.
