JOGC
Jun 02, 2023Aspirant
Can I add a RBS50 satellite to a CBR40 modem?
I have the Orbi AC2200 Tri-band WiFi Cable Modem Router (CBR40). Will the AC3000 WiFi Satellite (RBS50) Orbi Tri-band Add-on Satellite, 3Gbps, work with it? Thanks, JO
Jun 02, 2023Guru - Experienced User
Yes. Be sure FW is near same version as what cbr is using.
JOGC
Jun 03, 2023Aspirant
Thanks for your reply, altho I have no idea what FW is, LOL!
- FURRYe38Jun 03, 2023Guru - Experienced User
You can connect the RBS50 to the CBR via ethernet and see if it gets an IP address from the CBR, if so, use this IP address to try to log into the RBS web page using admin and password as the log in for the RBS.
What FW is on the CBR?
