JOGC
Jun 02, 2023Aspirant
Can I add a RBS50 satellite to a CBR40 modem?
I have the Orbi AC2200 Tri-band WiFi Cable Modem Router (CBR40). Will the AC3000 WiFi Satellite (RBS50) Orbi Tri-band Add-on Satellite, 3Gbps, work with it? Thanks, JO
Jun 03, 2023Guru - Experienced User
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Other satellites would work as well if you can't find an RBS50
JOGC
Jun 03, 2023Aspirant
Thanks for the chart!!
