Mguarnac
Jul 11, 2017Follower
Can I add a second satellite after purchase?
If I buy a Orbi RBK30 or RBK40 with a single satellite, can I add a second satellite to the system later?
- TC_in_MontanaVirtuoso
Yes, you can add a Satellite later.
There is a special process to follow on both the WEB GUI and the SmartPhone APP to add a new Satellite.
Hopefully you are not in Europe - I think they are still waiting for the Satellite ONLY to be sold there.
- TechloreApprentice
If you want to purchase an add on satelitte you can no problem. Amazon has a few of them, some more powerful than others so make sure to check which on you want before you buy.
