brunsonl
Mar 16, 2022Follower
can I add a wireless router in my shop?
cable internet into Orbi router, then into a powered switch for my cameras, from the powered switch I've run out to my shop for cameras. In the shop, it runs into another powered switch for added cam...
cummingselsie85
Mar 16, 2022Tutor
brunsonl CUIMS Login wrote:cable internet into Orbi router, then into a powered switch for my cameras, from the powered switch I've run out to my shop for cameras. In the shop, it runs into another powered switch for added cameras in the future. Can I install a second wireless router (Orbi or really any brand, I'm not sure I would need another orbi there) off of that switch for wireless in my shop? The signal is very bad out there, metal building, and a ways from the house.
If you already have an internet connection in your Home then there are various ways of extending a connection to your Outbuilding. The most reliable method by far is to run a Structured Data Cable, Permanent Link, or Hard Wired Connection from your ISP ( Internet Service Provider) Router to the outbuilding
