kproth's avatar
kproth
Tutor
Jun 19, 2018
Can I assign a Wired LAN port to the "guest" network
I have a MagicJack VOIP device plugged into a Wired LAN port on my Orbi RBR40 base station.  I'd like to treat it like it's on my guest network, specifically, I'd like to give it internet access only...
  • taohat's avatar
    Jun 20, 2018
    kproth wrote:
    I have a MagicJack VOIP device plugged into a Wired LAN port on my Orbi RBR40 base station.  I'd like to treat it like it's on my guest network, specifically, I'd like to give it internet access only and block access to all other Local LAN devices.  Is this possible?
    You could try connecting it to the LAN port of a client bridge (or sometimes known as a media bridge) that is connected to the Orbi base station via guest wifi. This seems to be able to achieve what you wanted.
