egan06
Mar 29, 2020Tutor
Can I bridge 2 x Orbi Routers
Hi, I have an RBR40 router and satalite. It was cheaper to buy another router with salelite (offer) instead of just the Satelite. So both satelites are working fine off my one Orbi Router. Can i u...
SW_
Mar 29, 2020Prodigy
It's worth it if WiFi signal can't reach where you plan to put the additional router, but it has to be a Wired Media Bridge (AP) on the existing Orbi LAN network.
