egan06
Mar 29, 2020Tutor
Can I bridge 2 x Orbi Routers
Hi, I have an RBR40 router and satalite. It was cheaper to buy another router with salelite (offer) instead of just the Satelite. So both satelites are working fine off my one Orbi Router. Can i u...
michaelkenward
Mar 30, 2020Guru - Experienced User
egan06 wrote:
Is it worth me putting the other spare orbi router upstairs on the same network?
Add the spare satellite to the Orbi router.
If that meets your needs, and delivers wifi everywhere, keep the second Orbi router as a spare.
egan06 wrote:
Not sure how and if this can be done?
Check the manual.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation, and, if there are any, firmware versions and drivers for your hardware.
Look for the model number on the label on the device.
