egan06
Mar 29, 2020Tutor
Can I bridge 2 x Orbi Routers
Hi, I have an RBR40 router and satalite. It was cheaper to buy another router with salelite (offer) instead of just the Satelite. So both satelites are working fine off my one Orbi Router. Can i u...
Mar 30, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
egan06 wrote:Hi, I have an RBR40 router and satalite. It was cheaper to buy another router with salelite (offer) instead of just the Satelite. So both satelites are working fine off my one Orbi Router. Can i utilise my spare router? My current setup is ...
1 x router downstairs
1 x satelite downstairs
1 x satelite upstairs.
Is it worth me putting the other spare orbi router upstairs on the same network? Not sure how and if this can be done?
Hope someone can help?
Thanks
Paul
