kelihjoll
Mar 12, 2018Aspirant
Can I buy an Orbi in the US to use in Europe?
Hi y'all. I'm travelling to the US later this month and want to pick up the netgear orbi to use at home as it's ridiculously expensive where I live (Iceland). So my question is: will I run into an...
Mar 12, 2018Guru - Experienced User
I would presume there will be differences in power compatibility US is 110v. Some of europe is 220v.
I would contact NG support and ask about this before buying.
http://netgear.com/support/contact.aspx
- kelihjollMar 14, 2018Aspirant
I know that the voltage isn't going to be an issue. It's everything else I'm worried about (https://community.netgear.com/t5/Orbi/Region-change-from-North-America-to-Europe/m-p/1429373/highlight/true)
- FURRYe38Mar 14, 2018Guru - Experienced User
Something to contact NG support about and ask before you buy.
