kelihjoll
Mar 12, 2018Aspirant
Can I buy an Orbi in the US to use in Europe?
Hi y'all. I'm travelling to the US later this month and want to pick up the netgear orbi to use at home as it's ridiculously expensive where I live (Iceland). So my question is: will I run into an...
Mar 12, 2018Guru - Experienced User
I would presume there will be differences in power compatibility US is 110v. Some of europe is 220v.
I would contact NG support and ask about this before buying.
http://netgear.com/support/contact.aspx
kelihjoll
Mar 14, 2018Aspirant
I know that the voltage isn't going to be an issue. It's everything else I'm worried about (https://community.netgear.com/t5/Orbi/Region-change-from-North-America-to-Europe/m-p/1429373/highlight/true)
