rsisson
Jun 26, 2018Aspirant
Can I change SUB NET MASK
Ok, we used to have a GOOGLE Wifi system.
It defaulted to 192.168.86.x and this has been giving me fits as I go around the house and have to reprogram everything that is WiFi.
I have ONE ...
Jun 26, 2018Guru - Experienced User
Try it, if the UI doesn't like that subnet, then it will let you know when you try to apply it...
rsisson
Alas it didn't work.
I set the Subnet to 255.255.0.0 hoping it would pick up the 192.168.86.?? address of the IP camera that was left stranded on that network.
I then ran a "Camera Finder" that uses MAC address and other network protocols I don't understand to find devices on the network with improper sub-nets and other addressing problems. I have been able to login to several other devices that were corrupted, reset the address and reboot and have them reappear on the network.. Not this one.
I will have to dig out the ladder and the "security" screwdrivers (weird shaped screws) and take it down, reset it, and replace it.
this time we are leaving it DHCP, and we will just reserve an address for it in the router DHCP table.
- st_shawJun 26, 2018Master
You could try setting Orbi to use 192.168.86.1/255.255.255.0. However, it sounds like there is a larger problem with that one camera, like maybe it's not connecting to WiFi at all.
