IdaS
Apr 23, 2019Aspirant
can I combine Orbi systems
Hi,
I have a Netgear Nighthawk with a Netgear extender but still nooks and crannies in my home without Wifi. So I am thinking of buying an Orbi system. A perfect setup for my home, at least on pape...
Apr 23, 2019Guru - Experienced User
Yes you can combine them. I would keep the satellites the same however if you get a RBK50. The wireless rates are different between a 50 series satellite and a 20/30 series satellite. I would get a RBS50 satellite if you need an additional satellite. The RBK50 somes with 1 satellite in the box.
30 feet is recommended in between base router and satellite to begin with depending upon building materials when wirelessly connected.
- IdaSApr 23, 2019Aspirant
Hi Furry,
Thanks for your quick reply. My home setup it a bit strange, that's why the Nighthawk + extender can't get everything covered. It are two separate small cottages with a room connecting them. Looks like an H, with extra floors on the legs of the H. I like the design of the RBS20 more than the bigger RBS50, that's why I hoped this could be a workable setup.
