IdaS
Apr 23, 2019Aspirant
can I combine Orbi systems
Hi,
I have a Netgear Nighthawk with a Netgear extender but still nooks and crannies in my home without Wifi. So I am thinking of buying an Orbi system. A perfect setup for my home, at least on pape...
Apr 23, 2019Guru - Experienced User
Yes you can combine them. I would keep the satellites the same however if you get a RBK50. The wireless rates are different between a 50 series satellite and a 20/30 series satellite. I would get a RBS50 satellite if you need an additional satellite. The RBK50 somes with 1 satellite in the box.
30 feet is recommended in between base router and satellite to begin with depending upon building materials when wirelessly connected.
IdaS
Hi Furry,
Thanks for your quick reply. My home setup it a bit strange, that's why the Nighthawk + extender can't get everything covered. It are two separate small cottages with a room connecting them. Looks like an H, with extra floors on the legs of the H. I like the design of the RBS20 more than the bigger RBS50, that's why I hoped this could be a workable setup.
- FURRYe38Apr 23, 2019Guru - Experienced User
What is the model of the NH and EX units you have now?
- IdaSApr 23, 2019Aspirant
The nighthawk is R7000 and the extender is EX6200
- michaelkenwardApr 24, 2019Guru - Experienced User
I have an R7800 at the front end of an Orbi system. The Orbit router is in Wireless Access Point mode.
If you still need the EX6200 after you set up the Orbi,. then it might function as a simple extender but without the wifi connectivity of the Orbi.
