IdaS
Apr 23, 2019Aspirant
can I combine Orbi systems
Hi,
I have a Netgear Nighthawk with a Netgear extender but still nooks and crannies in my home without Wifi. So I am thinking of buying an Orbi system. A perfect setup for my home, at least on pape...
IdaS
Hi Furry,
Thanks for your quick reply. My home setup it a bit strange, that's why the Nighthawk + extender can't get everything covered. It are two separate small cottages with a room connecting them. Looks like an H, with extra floors on the legs of the H. I like the design of the RBS20 more than the bigger RBS50, that's why I hoped this could be a workable setup.
Apr 23, 2019Guru - Experienced User
What is the model of the NH and EX units you have now?
- IdaSApr 23, 2019Aspirant
The nighthawk is R7000 and the extender is EX6200
- michaelkenwardApr 24, 2019Guru - Experienced User
I have an R7800 at the front end of an Orbi system. The Orbit router is in Wireless Access Point mode.
If you still need the EX6200 after you set up the Orbi,. then it might function as a simple extender but without the wifi connectivity of the Orbi.
- IdaSApr 24, 2019Aspirant
Thanks. I am sorry to say that I am probably not tech savy enough to combine the Orbi system with my Nighthawk, but thanks for the idea. After having slept on it, I think I maybe stick to what I have right now.
