gtyers
Aug 09, 2019Aspirant
can i connect 24 port switch RBK20
Would like to connect my RBK20 to TP link 24 port switch?
What setting do i need to change?
Sort By
Yes. Unmanaged and non green ethernet is preferred. If it happens to be a managed switch, disable ALL IGMP procotols on the switch.
- gtyersAspirant
yes its unmanaged.
do i just run the orbi in router or AP mode. any other settings i need to change?
sorry for the stupid questions.
Depends. Do you have a router upstream from the RBR?
If you don't have any router upstream from the RBR, then the RBR can run in router mode with the switch connected behind the RBR and all LAN devices to the switch.
