Sturg62's avatar
Sturg62
Follower
Aug 01, 2019
Can I connect a CM500V and Orbi CBK40 on Xfinity
I know CBK40 does not support ISP embedded voice on cable from ISPs. I have Xfinity as my cable provider and use aCM500V router for cable and phone. Won an Orbi CBK40 in a silent auction package and want to know if I can use it just as a wifi router by hooking it to CM500V through ethernet port to preserve my phone line
1 Reply
  • FURRYe38's avatar
    No. There two separate modems that work as modems. The CBR40 can be bridged, however this disables the wifi on the CBR40 and makes it just a modem only.
    Your best option if you want voice support, keep the CM modem and return the CBK40 system and get a Orbi RBK40/50 system.
    https://www.netgear.com/orbi/wifi-systems.aspx
    These systems don't have the built in cable modem and it's just the wifi router features that you would need to work with the CM voice modem.
