Darast
Mar 29, 2018Follower
Can I connect a Wi-Fi Extender to my Orbi Router?
Can I connect a Netgear WN2500RP WiFi extender to my router? If so how do I connect them?
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes you can connect a extender to orbi but it will create another separate network with a new SSID. And you connect the extender with the normal setup of the extender.
https://kb.netgear.com/23517/Installing-and-configuring-NETGEAR-WiFi-Range-Extenders
DarrenM
