masemasemase
Nov 05, 2021Aspirant
Can I connect an Orbi RBS350 Satellite to an Orbi RBR20 Router...?
The router (RBR20 - Firmware V2.7.3.22) is running in AP mode. I also have a hard-wired satellite (RBS20 - Firmware V2.7.3.22) which is running well. The guy at the store searched online and told m...
- Nov 05, 2021
I also have a hard-wired satellite (RBS20 - Firmware V2.7.3.22) which is running well.The guy at the store searched online and told me it would work :(
Any help would be much appreciated.
No. He is incorrect. (i.e. full of s**t)
Check the product data sheet (online)
https://www.netgear.com/images/datasheet/orbi/RBS350.pdf
Page 2 under "What do I need?" Orbi router RBR350.
None of the AX products are compatible with the older 802.11ac product line.
CrimpOn
Nov 05, 2021Guru - Experienced User
masemasemase
Bugger - thought that would be the case. Should have trusted my gut.
Thanks for replying. I'll stop troubleshooting now and put it back in the box.
