Alennetlove
May 07, 2020Follower
can i connect Mesh nodes of Orbi (RBK50) via ethernet cable?
hi guys
I would like to know is it possible to connect two Orbi mesh nodes via ethernet cable instead of wireless? I head netgear is working on firmware to make it work, does anyone done that so far? i am not looking for a workaround I would like to know if the firmware has that option or not.
Thank you for your help.
Alen.
Absolutely, yes. Plenty of participants in this forum use ethernet to connect satellite(s) to router.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
