GAP1
Jan 28, 2018Aspirant
Can I connect other lan devices into the same switch used for orbi RBK50 ethernet backhaul
Can I connect other LAN devices into the same switch used for Orbi the Ethernet backhaul ?? Orbi is in router mode with 2 satellites. Orbi router wan is wired to the modem and one of the LAN ports is wired to a large switch with both satellites wired to the switch. Thus, can I connect other LAN devices to the same switch used for Orbi the Ethernet backhaul?
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes you should be able to do this.
DarrenM
