JOATAMON
Jun 23, 2018Star
Can I create a 2.4GHz only guest network?
Don't laugh. Hear me out. I just replaced a 10 year old Airport Extreme with a Netgear Obi RBK50 (with the latest firmware update), and I love it. I gave the Orbi the same SSID and password as the ro...
- Jun 24, 2018
You can tell what band your iPhone is connected to by looking at the Attached Devices list in the Orbi web interface.
One other thing to try is to manually set your Orbi 2.4 GHz channel to 1, 6, or 11. There's a small chance that Orbi is using a channel the Nokia devices don't support.
st_shaw
Jun 24, 2018Master
JOATAMON
Jun 24, 2018Star
NAILED IT! My 2.4GHz network was on channel 13. Thanks. I'd never have thought of looking at that.
