Gojulas
Sep 22, 2020Aspirant
Can I do both Ethernet backhaul and Wireless?
Got a refurbished Orbi bundle off of Amazon. Orbi Router RBR20 Orbi Satellite RBS20 x 2 Right now everything is set up in the most basic out of the both configuration. Router in bedroom next to ...
CrimpOn
Sep 22, 2020Guru - Experienced User
Yes.... but.
A mix of ethernet and WiFi backhaul is supported. There are reports of problems when certain switches are between the router and the satellite. IF that turns out to be a problem, I would suggest plugging the cable into one port of the RBS20 and the switch into the other port.
