Gojulas
Sep 22, 2020Aspirant
Can I do both Ethernet backhaul and Wireless?
Got a refurbished Orbi bundle off of Amazon. Orbi Router RBR20 Orbi Satellite RBS20 x 2 Right now everything is set up in the most basic out of the both configuration. Router in bedroom next to ...
Mstrbig
Sep 22, 2020Master
Gojulas wrote:
Can I run Ethernet from the router to a switch in the TV room, and plug THAT sat. to the switch, while at the same time leave the sat. upstairs remaining completely wireless?
To avoid switch issues, you would want to run Ethernet from the router to the satellite in the TV room, then plug the switch into the satellite.
