lowrisk
Apr 04, 2019Tutor
Can I force a satellite to connect to a another one?
I recently having some issue with my setup, would it be possible to force my satelitte to connect to the another satellite?
I attached some screenshot. Please not that the "Kitchen" satellite on th...
- Apr 04, 2019
Might try using just two of the satellites. Kind of depends on the size of the home as well...
Apr 04, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming, Daisy Chain, and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain may help with getting satellites connected to each other. You can force them though.
Chuck_M
Apr 04, 2019Mentor
What you are describing is Daisy Chain.... that provides a Satellite to act as "man in the middle" to another satellite -- presumably farther out.
The term you used of "Forcing"... the concept of Mesh is that RF connections will be made to "best fit" what devices -- and satellites see in the RF environment. If the satellite -- with daisy chain enabled -- only sees a good signal from another, then it will try that connection.
Long and short is that daisy chain allows passthrough of one satellite to another to extend reach.
Make sense?
- lowriskApr 04, 2019Tutor
yes thanks, but I dont get how the system believes that connecting both to the main AP.
the last AP can't possibly have a better link with the main AP than the middle satellite due to its emplacement:
main orbi > 22feet in a straight(ish line) then > satellite 1 > 22feet satellite 2
