lowrisk
Apr 04, 2019Tutor
Can I force a satellite to connect to a another one?
I recently having some issue with my setup, would it be possible to force my satelitte to connect to the another satellite?
I attached some screenshot. Please not that the "Kitchen" satellite on th...
- Apr 04, 2019
Might try using just two of the satellites. Kind of depends on the size of the home as well...
Chuck_M
Apr 04, 2019Mentor
What you are describing is Daisy Chain.... that provides a Satellite to act as "man in the middle" to another satellite -- presumably farther out.
The term you used of "Forcing"... the concept of Mesh is that RF connections will be made to "best fit" what devices -- and satellites see in the RF environment. If the satellite -- with daisy chain enabled -- only sees a good signal from another, then it will try that connection.
Long and short is that daisy chain allows passthrough of one satellite to another to extend reach.
Make sense?
lowrisk
Apr 04, 2019Tutor
yes thanks, but I dont get how the system believes that connecting both to the main AP.
the last AP can't possibly have a better link with the main AP than the middle satellite due to its emplacement:
main orbi > 22feet in a straight(ish line) then > satellite 1 > 22feet satellite 2
