MicahD's avatar
MicahD
Star
May 22, 2022
Can I get wifi speed of 600mbps?
I recently upgraded my internet to a 600mbps package, after testing xfinity claims I'm getting that at the modem.  But my wifi speeds over my Orbi RBR50 mesh routers are between 300 and 400mbps, they...
  • Jeffgear's avatar
    May 22, 2022
    I have a 900/400mbps fibre plan and my MacBook Pro m1 on Ethernet to my RBR50 can consistently clock high 800's down and the max of 400 up. On WiFi it's half that and variable. My iPhone 12pro clocked 470 down on WiFi on a satellite but up is rarely above 100 up. WiFi upload rates quite low compared to Ethernet. My Ethernet connected old 4K Apple TV clocks 800 down, 300 up. This is using the downloaded Speedtest app and selecting my ISP's nearest server. The built in Speedtest app on the Orbi app cannot be changed from its chosen server (which is unknown) and only clocks 500 down and 110 up typically and this is when the Apple devices are giving much faster results. So the Orbi variant of Speedtest is not a good indicator.
