twobrain
Dec 18, 2020Aspirant
can i hard wire a satellite to another satellite that is connected wirelessly to the router?
getting poor performance from a distant satellite, can i just an ethernet cable between the 2 satellite to improve performance? thanks
- Dec 18, 2020
No difference. They just showed examples. People report using WiFi for the "first hop" all the time.
CrimpOn
Dec 18, 2020Guru - Experienced User
Yes, you can. See drawing #2 on this page:
- twobrainDec 18, 2020Aspirant
drawing 2, is showing the 1st satellite connected via ethernet to the router. wondering if it makes a diffrence if it is connected wirelessly?
- CrimpOnDec 18, 2020Guru - Experienced User
