ShadowHead
May 03, 2020Tutor
Can I have 3 VLANs in ORBI RBR50
Gents / Ladies: Cross linking this post from PFSense forum. I am curious if anyone has succeeded in getting 3 VLANS working on RBR50 in Router Mode. See attached network diagram. I seem to be abl...
May 03, 2020Guru - Experienced User
I don't believe so:
https://community.netgear.com/t5/Orbi/But-Orbi-DOES-have-Vlan-tagging/m-p/1811882#M72812
- ShadowHeadMay 04, 2020Tutor
Ok, thank you. Looks like it is not really VLAN support in ap roper way, just a 1 VLAN passthrough for IPTV. Thank you, wish I asked sooner. Wasted about 6 hours "playing" with this, even decending into Wireshark to take a look at the packets.
- FURRYe38May 04, 2020Guru - Experienced User
Good luck.
- HomerMitchellMay 12, 2020Aspirant
Exactly what I needed! You just saved me several hours. Thanks!
