martyfp
Jul 03, 2017Luminary
Can I lock devices to master/satellite ?
Is there any way to force specific devices to stay locked onto the Router and not switch to the satellite? I am using a wireless surround sound system (Samsung multiroom) which has four devices ...
DarrenM
Jul 05, 2017Sr. NETGEAR Moderator
Hello martyfp
No way to manually force the device to the router you could try re position the satellite and see if the router becomes a stronger signal for that device.
DarrenM
- martyfpJul 06, 2017Luminary
ok thanks. Interestingly, they are all now connected to the router and all is working OK.
