Windowpane
Mar 31, 2020Aspirant
Can I Place on Orbi satellite in an unheated room?
My Orbi satellite doesn't say anything about being an outdoor mesh extender, but that's what comes up here when I put the model number (RBS50) in above. If it is designed as an outdoor device, that...
Mar 31, 2020Guru - Experienced User
RBS are for indoor use while the RBS50Y is for outdoor use.
IF the room is enclosed and covered, you can put the RBS there. You might check the operation temp specs of the RBS to see what high and low temps it designed to work in.
- WindowpaneMar 31, 2020Aspirant
Thank you so much. I'll try to find that info. Be safe.
- FURRYe38Mar 31, 2020Guru - Experienced User
You too. :smileywink:
