Windowpane
Mar 31, 2020Aspirant
Can I Place on Orbi satellite in an unheated room?
My Orbi satellite doesn't say anything about being an outdoor mesh extender, but that's what comes up here when I put the model number (RBS50) in above. If it is designed as an outdoor device, that...
marine0816
May 04, 2020Aspirant
Any update? i have new Orbi AX6000 and need to put it in the detached garage.. How was your experience?
Thanks
May 04, 2020Guru - Experienced User
Be sure to post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Be sure to review the user manual and spec sheet for operating temp ranges.
marine0816 wrote:Any update? i have new Orbi AX6000 and need to put it in the detached garage.. How was your experience?
Thanks
