stealthpilot
Dec 13, 2016Aspirant
Can I plug the Arlo base-station into an Orbi Satellite?
I recently upgraded from the Apple Airport Extreme (I was running 4 Extremes as a mesh) to Orbi (I have a basestation and 3 Orbi Satellites). With the Apples if I connected the Arlo basestation t...
loomis1975
Dec 14, 2016Luminary
I would try plugging the Arlo into the nearest existing Satellite to an optimal location and see if the disconnections stop happening before adding another satellite to the mix. Are you experiencing any other disconnections? I ask because you have a router and three satellites, thats a lot of wifi using the same SSID. Depends on how spread out they are I guess.
