JDB190
Aug 27, 2017Aspirant
Can I put a thumb drive with music on the Orbi
I have some wifi definitive technology speakers. I had a night hawk ac1900 and I put a thumb drive into the router USB slot and I was able to access the music files on my difinitive tech. Apps. It di...
DarrenM
Aug 29, 2017Sr. NETGEAR Moderator
Hello JDB190
Orbi only supports printers via the usb port at this time.
DarrenM
Bing-Stroller
Aug 29, 2017Luminary
Yes,
I am using the standard Firmware V1.12.0.18 and I currently have music and video files on a 16GB PNY thumb drive which is attached to my Orbi router.
Using VLC Local Network connections I can select READYSHARE from the options which then displays USB_Storage which in turn displays the loaded folders/files.
Both videos and music play perfectly in VLC.
I have tried various other USB drives but so far only the PNY drive has worked for me.
- JDB190Sep 01, 2017AspirantThank you for your response but does it matter if it is a 2.0. Or a 3.0 thumb drive? Thank you for your help.
- Bing-StrollerSep 02, 2017Luminary
It's actually marked up on the router as USB 2.0 so that's what I used.
As previous - of the ones I tried, PNY was the only one that worked with my router.
