Pmohanti
Mar 24, 2019Follower
Can I Replace Netgear Wireless Gateway(CG3000D) with Orbi?
I have a Netgear Wirless Gateway (CG3000D) and have been using for years (even after moving from an apartment to a house of 2500 sq ft). Now that I have increases home automation devices into my smart...
Mar 25, 2019Guru - Experienced User
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Pmohanti wrote:
I have a Netgear Wirless Gateway (CG3000D) and have been using for years (even after moving from an apartment to a house of 2500 sq ft). Now that I have increases home automation devices into my smart home hub shall I replace my exisiting wifi hub with something like orbi.
If yes what is the best and economical recommendation ?
