StuMcBill's avatar
Jan 04, 2019
Can I route all traffic through a VPN?
Hi,
Can I setup the Orbi to route all my internet traffic through a VPN?  I've read that the VPN service section under advanced setup doesn't work like that?  If not, is there anyway I can do this?
Thanks,
Stewart
  • Orbi's VPN is for remote access to your LAN.  To do what you describe, you would need to run Orbi in Access Point mode behind a third party router that supports VPN as a client.
1 Reply
