Riley-Mac's avatar
Riley-Mac
Follower
May 26, 2020
Can I run my RBR10 router without the satellite and still get good results.
Greetings.   the RBR10 mesh system comes with a router and one satellite.  With the satellite connected wifi speed is great but my internet speed is greatly reduced.  I therefore thought I could run just the router.  It does work that way buy my wifi strength has been greatly reduced, even for those devices close to the router.
Is there some way to configure the router so I get better results.
Thanks for any info you can provide.
1 Reply
  • FURRYe38's avatar
