RICHTBISQWIT's avatar
RICHTBISQWIT
Follower
Feb 13, 2024
Can I use a VPN with RB50 and which is most suitable?
I’m looking to improve home online security, having two teen girls and being a work from home family means that I should probably have done this a while ago!
i want to set-up a VPN for use at home, with our ORBI RB50 mesh.
There seems to be a lot of conflicting information about as to whether it is possible to do this, with some saying that ORBI does not support VPN and others stating that it is possible, so I thought I’d ask a more knowledgeable source!
There are many devices that run at home, so setting up individual VPN’s seems like a potential nightmare, but setting one up with the ORBI seems to be a best solution.
Is it possible, and which one do people use?
Thanks in advance,
Rich
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Alas, Netgear routers do not include the VPN feature you seek.  The only solution is to sign up with a VPN service that provides software for the devices which need it (computers, laptops, tablets, smart phones).  There are plenty of reviews on the internet comparing VPN services.
    What Netgear does include in WiFi routers is the ability to create a VPN Host on the router using a version of the open source OpenVPN. https://en.wikipedia.org/wiki/OpenVPN   The purpose is to allow the owner of the system an encrypted pathway to connect to the local network from the internet.  This might be to check on devices running on the LAN or even to manage the WiFi router itself.  This is exact opposite of your goal which is to access internet resources from inside the LAN.
