bob_dylan
Feb 16, 2022Aspirant
Can I use CBK40 as just a router?
TL;DR: Can I use the Orbi CBK40 as a router only? If so, are there some simple instructions to follow to do so? I switched from cable to fiber recently. The fiber company installed a new modem an...
Feb 16, 2022Guru - Experienced User
I don't have that device to test with but some of the older modem/router combo devices you could turn into a sort of access point. Not a router because you have to disable dhcp.
you can try that and see if it works. if no, you can usually find used rbr50/40's on ebay because people will buy the kits for the satellites and resell the router.
