relvix
Apr 18, 2021Follower
Can I use network cable to connect a router with a satellite
Hi, I have a RBR40, i.e., one RBR40 and one RBS40. I will be moving soon. If my bedroom is wired for Ethernet, can I connect the RBR40 with the RBS40 using a LAN cable (through the Ethernet jack in m...
swjmcdonnell
Apr 18, 2021Aspirant
Yes, that should work fine. Instead of wireless backhaul, you will have wired backhaul, which is probably even faster than if they were communicating wirelessly (even on a dedicated 5GHz channel).
- plemansApr 19, 2021Guru - Experienced User
It should work great. The wired backhaul will put the RBR40 system in the performance range of the RBR50 system as the backhaul was the primary difference between the 2.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
